How to define variable flux on a wall
Old   July 17, 2013, 16:27
Default How to define variable flux on a wall
Qasim Ali
mqasimali is on a distinguished road
Send a message via Yahoo to mqasimali Send a message via Skype™ to mqasimali
hello friends,
i have been simulating a flow blockage through a coolant channel of fuel assembly.
i have finished the analysis in 2d as well as 3d with average value of heat flux and results are very close to expected results.
now to achiever further refinement in my results i want to use variable heat flux along the length of channel, is there any way i could enter function of flux or variable flux to the wall in 2d or surface in 3d case????
mqasimali is offline   Reply With Quote
Old   July 17, 2013, 22:21
blackmask will become famous soon enough
Why not? The macro
DEFINE_PROFILE
would do the job.
blackmask is offline   Reply With Quote
Old   July 18, 2013, 17:20
Qasim Ali
Thank you bro,
i got that option ova there but tell me what is the input file format that fluent will read?
and what is the sequence to define that profile, can you help me with a text format for it?
Old   July 18, 2013, 20:01
The DEFINE_PROFILE I mentioned is a macro of user defined function. You might have read the part on "profile", while is a file format. Either could be used to achieve what you wanted. The former could be easier and more efficient to implement if you have the analytical expression for the flux. You should consult the manual for the "profile" data format.
variable heat flux
Radiation interface hinca CFX 15 January 26, 2014 17:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Heat Flux Wall Boundary Confusion. Joee FLUENT 1 August 21, 2010 12:20
wall heat flux between two fluid zone!!! Asghari FLUENT 2 August 25, 2006 10:11
WALL HEAT FLUX tommy CFX 0 December 20, 2005 12:42
