Conjugate Heat Transfer Issue
Old   July 15, 2013, 15:20
Default Conjugate Heat Transfer Issue
Ravi Agrawal
abc197 is on a distinguished road
Is it possible to assign a constant temperature at interface(and interface_shadow) while coupled boundary condition is assigned for both.
In my case, I assigned a fixed temperature in solid cell zone, but interface temperature comes out much higher than this value. Somebody help please.
abc197 is offline   Reply With Quote
Old   July 16, 2013, 03:25
Yash Ganatra
yashganatra is on a distinguished road
Hi, I am having some issues with conjugate heat transfer. How did you create coupled walls?
yashganatra is offline   Reply With Quote
Old   July 16, 2013, 04:03
Ravi Agrawal
I think , wall boundary condition should be used for interface in the pre-processor, then fluent will generate itself interface name_shadow boundary. You will see then coupled BC option for both and same should be used for conjugate effects.
Old   July 21, 2013, 14:07
ssixr's Avatar
sudhir
ssixr is on a distinguished road
what BC did you give for fluid zone?
ssixr is offline   Reply With Quote
Old   July 21, 2013, 23:49
Ravi Agrawal
At both fluid side and solid side interfaces, coupled BC is used. In cell zone conditions, for solid zone, I used fixed temperature, while for fluid zone, I did not specify any thing there. I used as usual BCs for fluid zone boundaries.
I guess its not possible to assign constant temperature at interface in conjugate case. We use coupled BCs there and its temperature will vary throughout.
ansys, conjugate heat transfer, fluent, interface, wall boundary condition
conjugate heat transfer with phase change mogoko CFX 2 March 23, 2011 11:25
Conjugate Heat transfer in CFX ksp1717 CFX 11 December 10, 2010 22:07
Conjugate Heat Transfer of Motorized EGR enr_venkat CFX 1 October 12, 2010 18:17
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 18:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
