1-Way FSI-Transient-Time Stepping
Old   March 16, 2013, 10:51
Default 1-Way FSI-Transient-Time Stepping
Gowrav Shenoy
Gowrav is on a distinguished road
I am doing my masters project on FSI of microturbine to evaluate stress on blades.. I have completed CFD Part in Fluent. Also linked the result to Transient Structural as Workbench Procedure. I have successfully imported pressure on blades. Also given equivalent time steps as i given in transient fluid analysis previously.. But still its not matching in Analysis Settings..
I have also kept node-to-node connectivity btw solid and fluid( am not sure whether its required or not).
180k elements-tet. 720 time steps each of 3.33e-6s
What might ve went wrong,, whether its bcs of tiny time step?
( i am able to get results for steady state CFD and Static Structural Analysis bt its not working with transient, also am unable to import transient CFD results as Static Load in Static Structural)
kindly looking for help..
Thanks in Advance
Gowrav
Gowrav is offline   Reply With Quote
Old   March 18, 2013, 12:22
stumpy is on a distinguished road
There's no automated mapping between transient CFD and transient structural. Two options:
1. Use the External Data component (export CFD results to ASCII files, then follow the documented External Data procedure for importing multiple files)
2. Take a look at "FSI Transient_R145_v1" on https://support.ansys.com/AnsysCusto...ry/ACT+Library
stumpy is offline   Reply With Quote
Old   July 23, 2013, 04:28
tmeysam92
tmeysam92 is on a distinguished road
thanks Stumpy
i do not have a user name and password for customer portal.
is it possible to upload one of the tutorials about coupling transient structural and fluent?
tmeysam92 is offline   Reply With Quote
Old   July 23, 2013, 16:39
If you have a valid license or your university has a valid license then you can register for the portal.
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
Time step in transient simulation shib FLUENT 0 June 17, 2010 13:07
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
