July 27, 2013, 13:22 |
Flow does not arrive outlet but is converged
FHydro
Rep Power: 13 |
Hello.
I am modeling a steady state channel with two inlet for water and air (velocity inlet) and with 1 outlet(pressure outlet). In the middle of channel two inlet with pressure inlet are for aeration. (i am not using open channel flow in multiphase panel) After 814 iteration fluent is writing " solution is converged" but the flow does not arrive to outlet? I am very confused. The residuals for all parameters are 1e-3 I decreased the continuity residual criteria to 1e-5 but i want to know what the problem is? I think the continuity residual should not arrive to 1e-3 because the inlet are not equal to outlet. The attached image is residuals Please help thanks Last edited by flow_CH; July 27, 2013 at 15:06. |
reversed flow in xxxx faces on pressure outlet | franzdrs | FLUENT | 8 | January 4, 2020 20:12 |
Outlet BC for disturbed Poiseuille flow | murx | CFX | 10 | February 22, 2012 13:55 |
Duct Flow with 90 degree inlet and outlet | k | FLUENT | 3 | August 19, 2007 14:30 |
pressure outlet (open channel flow) | Willem Brantegem | Main CFD Forum | 0 | April 3, 2007 09:39 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
