DPM results same as in converged continuous flow |
July 29, 2013, 04:58 |
Same results in DPM as in continuous phase
Nick
Rep Power: 16 |
Dear all,
I am having problems calculating the lift and drag coefficients of a s809 wing in a 2phase flowfield (air+rain droplets).I am running the continuous phase first and get both a 1st and a 2nd order convergence.Then i insert the dpm parameters in define>models>dpm and set the wing boundary condition but it seems like im getting the same results as in continuous phase.Any suggestions?Thanks in advance. Last edited by yoooodarulez; July 30, 2013 at 16:56. |
July 29, 2013, 06:29 |
Nick
Rep Power: 16 |
My input for DPM is:
-Interaction with continuous phase -10 continuous phase iterations per DPM iteration -Unsteady Particle tracking -Particle Time Step size 0.001 -Number of Time Steps 1 -Max number of Steps 500 -Step Length factor 5 -Spherical drag law -Droplet breakup/TAB/y0/2 parcels and for the injections i use a surface type injection released from a plane ahead of my wing in the YZ plane which is releasing inert particles of water liquid with properties namely: -x vel:the mainstream velocity 29.215 -y vel:the velocity computed from Gunn kinzner equation -3.77327 -diameter:0.0009 -start time 0 -stop time 1000 -total flow rate 0.87645 kg/s (but in here i havent included any area value i have just computed this mumber by multiplying LWC with the mainstream x-velocity) |
July 30, 2013, 13:16 |
Nick
Rep Power: 16 |
Ok let me pose another question since i figured it out what was wrong anyways.Is there any way to increase the splashed particles apart from introducing more particles?I kept increasing the surfaces from 1 (initially) to 4 surfaces releasing particles and the particles released did increase but the splashed particles came to a limit as it seems.Any suggestions?
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 05:36 |
DSMC results of low-Mach flow over circular cylinder | flotus1 | Main CFD Forum | 2 | November 13, 2012 10:37 |
Two-phase flow in T-junction, multiphase of DPM? | Tony | FLUENT | 2 | July 8, 2008 01:26 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
computation about flow around a yawed cone | Tylor Xie | Main CFD Forum | 0 | June 9, 1999 07:33 |
