same velocity in inlets
Old   July 29, 2013, 11:43
Default same velocity in inlets
rayan
rayan24 is on a distinguished road
I want to impose by UDF a same velocity profile in 3 inlets, but i don't get same velocity in the 3 inlets apparently i impose my profile in function of the distance r!!
how can i impose my velocity profile in the "surface" of inlet to get samevelocity please??
my udf is :
HTML Code:
#include "udf.h"
DEFINE_PROFILE(w_velocity_inlet,t,i)
real x[ND_ND]=3; /* this will hold the position vector */
real r;
face_t f;
begin_f_loop(f,t)
F_CENTROID(x,f,t);
r = x[0];
F_PROFILE(f,t,i) = -((0.0431*pow(r,3))-(0.3857*pow(r,2))+(0.3129*r)+8.8045);
end_f_loop(f,t)
thanks
rayan24 is offline   Reply With Quote
Old   July 29, 2013, 15:58
Amir's Avatar
Amir
Amir is on a distinguished road
Dear Rayan,
Your profile is a function of x-coordinate, so you will get different results if the elements of these inlets have different x positions! Did you expect something else?!
Bests,
Amir
Amir is offline   Reply With Quote
Old   July 29, 2013, 17:14
rayan
Tank you Amir for your replay,
My 3 inlets are aligned in the XY plane, so the Inlet 1 ranges between x = [1, 4.5], inlet 2 is between x = [5, 7.5] and the inlet 3 is between x = [5, 7.5], so I can't get to impose my velocity profile in each inlet!
Do you have an idea please?
Old   July 30, 2013, 03:41
Amir's Avatar
Amir
There are lots of options. You can either use if-clauses to switch between different thread IDs or simply use 3 UDFs.
Bests,
Amir
Old   July 30, 2013, 03:46
rayan
Thanks for your response
Old   November 19, 2013, 06:41
Default Udf
muhamed
Mohammad80 is on a distinguished road
Hello Amir,
Could you please help me?
I have a problem writing a UDF for my 2D-geometry.
I hope you have time to contact me at my E.mail address:
mas20001920@yahoo.com
Best regards.
Mohammad80 is offline   Reply With Quote
WSS and normal velocity gradient for the slanted pipe wanna88 FLUENT 2 October 1, 2012 22:34
Problem with time average tangential velocity in swirl flow. lakhi FLUENT 5 July 18, 2012 16:28
how to compute relative velocity from absolute? spk Main CFD Forum 3 July 9, 2010 08:42
Is it possible to have multiple velocity inlets in your model boundarylayer FLUENT 0 June 5, 2010 02:29
Multiple Inlets Charlie V FLUENT 0 May 28, 2001 02:29
