grid study, important question
Old   February 9, 2012, 11:44
Default grid study, important question
hamid
hamid1 is on a distinguished road
Dear Friends
I have a very important question regarding the mesh study (grid independency study)
My simulation is based on mesh A in which the element size (done in ICEM) is 0.15 and the total number of elements is 1 934 000 mesh,
For grid study I decreased the size of element for two times (mesh B and C), every time it became smaller with the ratio of 15%,
So, for mesh B, the size of element is 0.1275 and the number of element is 3 048 000 mesh and
for mesh C, the size of element is 0.108375 and the number of element is 5 000 000 mesh,
then I investigated the critical parameter in the critical zone, (the difference between mesh C and A was 4%)
- My question is, whether my Grid study (independency) procedure is correct or not?
- I got a bit confused about the amount increase in elements or decrease in element size regarding to grid study as every source tell something different… is reducing the size every time by 15% OK?
Thank you very much for ur helps
Hamid
hamid1 is offline   Reply With Quote
Old   August 4, 2013, 00:14
aeroAngel's Avatar
Fateme Sh
aeroAngel is on a distinguished road
it depends on the system you have.
in a REAL Grid-study,number of elements should be like about 1,000,000 and 10,000,000 and 20,000,000 .
but for a normal user without any powerful system,you've done a good job.
and the results for the element range that you've used won't differ a lot, and i think you've got correct results
aeroAngel is offline   Reply With Quote
Grid Refinement Study - How many cells necessary for accurate results? ejvikings FLUENT 1 January 22, 2012 00:33
What type of analysis can be done for case study grid independence? warlocklw CFX 1 November 15, 2011 19:22
Grid Independency Study pchoopanya FLUENT 1 August 10, 2011 23:09
Problem with Grid convergence study dialolema CFX 1 June 14, 2010 18:33
Moving Body Grid Question Matt Main CFD Forum 5 September 13, 2004 00:45
