Converged solution changes upon restarting
Old   August 28, 2013, 11:49
Default Converged solution changes upon restarting
athan
achat is on a distinguished road
Hello:
I am using ANSYS FLUENT v14.0.
i am solving a steady-state, fiber coating problem in a fairly complex geometry with surface reactions. The equations solved are momentum, energy and a few species concentrations. For the low diffusivity cases (low operating tempeartures) I seem to get converged solutions (residuals are very low and plateau out). But when I restart, the converged solution changes: the residuals spike and then they plateau out! This does not happen when diffusivities are high (high T).
Any ideas/suggestions as to why the solution gets 'trapped' in an artificial converged state for the low diffusivity cases? I am using 'coupled' pressure-velocity coupling with second-order upwind.
Thanks
athan
achat is offline   Reply With Quote
steady-state convergence
simple solution converged in 9 iterations? Gabbee90 OpenFOAM Running, Solving & CFD 4 January 29, 2019 21:04
grid dependancy gueynard a. Main CFD Forum 19 June 27, 2014 21:22
smoothSolver diverges - solution in using PBiCG solver? makaveli_lcf OpenFOAM Running, Solving & CFD 3 September 11, 2013 12:44
solution is not getting converged Nijanthan FLUENT 5 July 25, 2013 01:42
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
