Fluent Line Command
Old   August 30, 2013, 21:30
Default Fluent Line Command
shashank vummidi
shashankvu is on a distinguished road
I am trying to set up boundary conditions via the command line (want to replicate the conditions shown in the jpeg file attachment) ....
define/boundary-conditions/velocity-inlet inlet_2 no no no no
I am trying to change the progress variable in the command line, but I am getting the following error,
define/boundary-conditions/velocity-inlet (inlet_1 inlet_2)
inlet_2 no no no You must select one of the Velocity Specification Method options.
no
Velocity Specification Method: Components [no] it Please answer y[es] or n[o].
Please answer y[es] or n[o].d: Components [no] file/stop-journal
Velocity Specification Method: Components [no] /exit Please answer y[es] or n[o].
yes
Reference Frame: Absolute [yes] Use Profile for Supersonic/Initial Gauge Pressure? [no] Supersonic/Initial Gauge Pressure (pascal) [0] Use Profile for Axial-Velocity? [no] Axial-Velocity (m/s) [0] Use Profile for Radial-Velocity? [no] Radial-Velocity (m/s) [0] Turbulent Specification Method: K and Omega [yes] Use Profile for Turbulent Kinetic Energy? [no] Turbulent Kinetic Energy (m2/s2) [1] Use Profile for Specific Dissipation Rate? [no] Specific Dissipation Rate (1/s) [1] Use Profile for Progress Variable? [no] Progress Variable [0] Use Profile for Progress Variable Variance? [no] Progress Variable Variance [0] Use Profile for Mean Mixture Fraction? [no] Mean Mixture Fraction [1] Use Profile for Mixture Fraction Variance? [no] Mixture Fraction Variance [0]
> Halting due to end of file on input.
I would appreciate any help in trying to describe the velocity inlet via the command line
shashankvu is offline   Reply With Quote
[OpenFOAM.com] erros in Allwmake jiwon OpenFOAM Installation 7 December 30, 2015 12:34
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
Install problem in linux navaladi OpenFOAM Installation 11 July 17, 2008 02:24
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
Options when running Fluent from the command line An Modh Coinniolach FLUENT 2 January 14, 2003 04:11
