2d les
Old   September 14, 2013, 11:26
Default 2d les
PSM
pitamber.methia is on a distinguished road
I am using the command (rpsetvar 'les-2d? #t) in fluent
the following message comes in dialog box
Error: rp-var-value-set!: undefined variable
Error Object: 2d-les?
can anybody help. does my system should have visual studio then only it will work
Regards
pitamber.methia is offline   Reply With Quote
Old   September 15, 2013, 14:22
Default found the mistake
PSM
1. open a 2D case file
note: check Define/Models/Viscous to verify that LES is not present for a 2D problem
2. type (rpsetvar 'les-2d? #t) and press enter
note: you have to include the parentheses
3. go to: Define/Models/Viscous and you'll see that the LES model has been enabled for the 2D case.
turbulence is a 3D phenomenon and so, by using it to model a 2D problem your results may lose some of their predictive capabilities.
LES Filtering: how are the small and large scales equations solved? atmcfd Main CFD Forum 38 March 14, 2016 14:52
Beginning to work in LES - Suggestions needed atmcfd Main CFD Forum 5 July 20, 2012 22:16
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 11:35
LES on two phase flow Li Yang Main CFD Forum 0 May 12, 2004 08:10
Some Questions about LES. Bin Li Main CFD Forum 2 February 20, 2004 09:58
