Different strategy of convergence, different solution
Old   October 4, 2013, 16:34
Default Different strategy of convergence, different solution
DavidB is on a distinguished road
Hi!
I simulating a transonic wing with airplane body and air inlet behind the wing . I use pressure far filed, pressure outlet for the limits of the domains and a pressure outlet with target mass flow rate for the inlet. Density based with Rke.
If i achieve the convergence starting from the first order and at the end the second order I obtain ad solution that's different from the ones that i achieve starting the solution from a lower incidence solution with the second order active from the start.
Anyone has the same problem (in terms of discrepancies of the solution)?
DavidB is offline   Reply With Quote
How to find a good time scale strategy? StefanG CFX 19 June 8, 2012 08:41
Solution convergence problem - poor mesh? Shawn_A OpenFOAM Running, Solving & CFD 2 November 12, 2011 19:31
Force can not converge colopolo CFX 13 October 4, 2011 22:03
solution convergence problem anbuselvan FLUENT 1 January 18, 2009 04:00
[HELP]mixing plane convergence strategy?? Pak FLUENT 0 October 23, 2001 01:22
