[Linux] Minor problem with flexlm lmgrd process
Old   October 19, 2013, 10:48
Default [Linux] Minor problem with flexlm lmgrd process
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Hi my friends!
I'm planning to migrate from windows 7 64 bit to linux 64 bit: I use fluent and gambit and my current setup is to run fluent in windows 7 with an hpc license for 12 processors and gambit inside a linux 64 bit virtual machine to have all the 64 bit for meshing.
However I can install fluent directly in linux 64 bit, so to avoid the virtual machine I'm planning this migration.
After about 2 days I was able to run Fluent 14.5.7 on kubuntu 64 bit; all is ok, license is correctly read.
However I have a minor problem:
when I reboot or start the os the license server is not started (licensing interconnect, licensing interconnect monitor and flexlm).
After starting /usr/ansys_inc/shared_files/licensing/lic_admin/anslic_admin I can see all the 3 "not running".
When I click on "start the ansys inc license manager" licensing interconnect and licensing interconnect monitor show as running but not flexlm.
With the command ps -A to list all the processes I have 2 lmgrd processes running:
2806 ?        00:00:02 ansysli_server
2812 ?        00:00:00 ansysli_monitor
2816 ?        00:00:00 lmgrd
2895 ?        00:00:00 lmgrd
If I kill the first lmgrd (sudo kill 2816) then on anslic_admin window flexlm turns on running and all work!
Why lmgrd starts 2 times?(before clicking on "start the ansys inc license manager" ps -A shows no lmgrd processes)
How can I automatically and correctly start the license server?
Thank you!
Daniele
PS:
making a sh file in sbin folder and start at boot doesn't work (licensing interconnect and licensing interconnect monitor are running but not flexlm)
ghost82 is offline   Reply With Quote
License trouble: ANSLIC_ADMIN, FLEXlm not running, but two lmgrd processes running! dancoz87 ANSYS 17 November 14, 2016 01:10
License Error lffabiani CFX 2 June 30, 2011 20:51
problem with starting ansyslmd Mike CFX 0 March 2, 2005 07:59
