Mesh Morpher/ Optimizer for drag reduction - control point movement
Old   July 23, 2013, 11:26
Default Mesh Morpher/ Optimizer for drag reduction - control point movement
John
J_Mann is on a distinguished road
Hello all,
I am currently running a simulation on a 3D wing and have made a few manual design iterations simply by changing a CAD file and re-meshing from scratch. I am now trying to use the new mesh optimization in Fluent 14 by selecting parameters as the objective function.
The main part I don't understand is that when you have created the region that is going to change (or morph) with a number of control points you then have to define the scale and direction (deform tab) to move each control point.
Why is this necessary if you have no movement constraints on the surfaces you wish to deform? Is it just to start an iterative geometric shape change or does it constrain the morphing somehow?
Any advice would be much appreciated as I have no support from Ansys and this topic is very hard to find advice on elsewhere!
Thanks,
John
J_Mann is offline   Reply With Quote
Old   October 25, 2013, 05:38
Mads
Mobz is on a distinguished road
Hi John
Im like you also trying to figure out how to use the Mesh Morpher/ Optimizer in Fluent.
Do you have any luck with it?
Everytime I try I get an error saying that I have left-handed-faces nodes in my mesh
Mobz is offline   Reply With Quote
Old   October 25, 2013, 15:29
John
No I had to move onto something else I'm afraid. I think left handed faces means essentially the mesh has become inverted somewhere so it's moved too far in one design iteration. If you reduce that it might help? Not sure but could be worth trying.
Good luck and let me know if it works I'll be picking it up again in a couple of months so could do with the advice!
control points, mesh morpher, optimize, optimizer, shape optimize
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 08:52
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
How to mesh the 1st grid point? Daniel Main CFD Forum 1 October 8, 2007 02:27
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
