Parallel processing (Please help)
Like Tree1Likes
  • 1 Post By lalit kumar
Old   March 10, 2010, 09:44
Default Parallel processing (Please help)
Mohsin Mukhtar
Mohsin is on a distinguished road
Hi
Actually I have a problem when i try to use Fluent post processing. It says go to "Run" and wirte "cmd" then write "fluent -t3", When i do it, it gives me an error " Fluent is not recognized as an internal or external command, operable program or batch file". Please help me so that I can start the simulation.
My system specification is 4GB ram, Intel Quad, 64 Bit Windows 7, Memory 400GB in C (where fluent is installed) and 400 GB in E (where I save the .dbs,msh files).
Please Help
Mohsin
Mohsin is offline   Reply With Quote
Old   March 10, 2010, 12:47
jpo
jpo is on a distinguished road
Please search the forum. Most likely, your PATH variable needs to be modified
(All Programs --> Fluent --> Set environment)
jpo is offline   Reply With Quote
Old   March 10, 2010, 14:18
msth is on a distinguished road
You have to check to see where the exe file "fluent" is.
It is usually inside your fluent directory in "ntbin/ntx86". The directory could be named as "fluent 6.3" or "fluent.Inc" in your computer.
msth is offline   Reply With Quote
Old   March 11, 2010, 10:06
Mohsin Mukhtar
I tried the method but was not successful until someone gave me a file named "mpich2". I dont clearly know what this might be but may be soomething which gives access to fluent parallel processing. After installing that it worked. Thank you for your replies by the way.
Old   March 11, 2010, 13:48
lalit kumar is on a distinguished road
u can use parallel fluent by doing
right click on fluent desktop icon, on the fluent path add -tn (n=no of processor in CPU, e.g. -t2). for my computer it's
C:\Fluent.Inc\ntbin\win64\fluent.exe -r6.3.26 2ddp -t4
flow_CH likes this.
lalit kumar is offline   Reply With Quote
Old   October 29, 2013, 03:26
FHydro
flow_CH is on a distinguished road
It worked very well. I have corei5 with 4 GB ram in win7 64bit.
The address that it worked is C:\Fluent.Inc\ntbin\ntx86\fluent.exe -r6.3.26 2d -t3 . I can change -t3 to -t4 but the cpu usage is going to 100%
Thank you
flow_CH is offline   Reply With Quote
parallel processing
Parallel processing of OpenFOAM cases on multicore processor??? g.akbari OpenFOAM Running, Solving & CFD 31 November 1, 2017 09:25
HP MPI warning...Distributed parallel processing Peter CFX 10 May 14, 2011 06:17
bubbly flow and parallel processing mvee FLUENT 0 September 12, 2007 05:08
FEDORA CORE and PARALLEL processing Tuks CFX 2 August 20, 2005 11:05
About parallel processing in Linux tuks CFX 10 August 8, 2005 08:22
