October 29, 2013, 11:43 |
The end of unsteady flow
FHydro
Hi.
I am modeling an unsteady flow in fluent(implicit). With changing the time step, i can achieve to converging, but after converging the iteration is continue, so How can i understand the simulation is done and i can export the results? Thanks |
October 30, 2013, 00:42 |
Maxime Perelli
Rep Power: 41 |
by decreasing (I suppose) the time step size (dt), your solution converges faster FOR A TIME STEP (t). That means the solver switches on next time step (t+dt) untill time step t reaches the number of time steps you set (N)
In this example, dt = 5e-5 s N = 2000 That means calculation will be over for t = N * dt = 2000 * 5e-5 = 0.1 s
In memory of my friend Hervé: CFD engineer & freerider |
October 30, 2013, 05:12 |
FHydro
Thank you for reply
1- In my case, by decreasing the time step size (dt), the residuals are going up and more diverge . 2- I do not anything about the time of ending the flowing in my model, so which time i should stop the processing? |
October 30, 2013, 05:26 |
Maxime Perelli
Rep Power: 41 |
1- weird
2- it depends on what you want to compute (your physics)
October 30, 2013, 05:41 |
FHydro
Can i stop processing when the results do not change after more iterations?
October 30, 2013, 06:12 |
Maxime Perelli
Rep Power: 41 |
For sure
(you should ask: "Can i stop processing when the results do not change after more time steps")
October 30, 2013, 07:35 |
FHydro
I am asking: Can i stop processing when the results do not change after more time steps ?
October 30, 2013, 07:44 |
Maxime Perelli
Rep Power: 41 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
No results for solid domain | Gary Holland | CFX | 10 | March 13, 2009 03:30 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 6, 2008 23:17 |
error using combination of step function | xujjun | CFX | 1 | January 15, 2008 16:46 |
