Access violation error with Fluent 6.2
Old   May 22, 2007, 12:33
Default Access violation error with Fluent 6.2
Prasad Dudhgaonkar
Hello there,
When setting an airblast atomizer injection, I'm getting an error FLUENT received fatal signal (ACCESS_VIOLATION). I have gone through concerned chapters of Fluent User's Manual for Fluent 6.2. Can anybody educate me about the possible causes at the earliest?
Thanks in advance. Prasad
Old   May 22, 2007, 13:18
Default Re: Access violation error with Fluent 6.2
Allan Walsh
Are you using a UDF? I have gotten this error when trying to address a variable that I didn't have access to.
Old   May 22, 2007, 13:56
Prasad Dudhgaonkar
Thanks Allan for your reply.
I don't use UDF. I have an annular tube and have to inject particles using airblast atomization model (available in Fluent). I get this error when I try to list the injection.
Old   May 22, 2007, 14:01
Prasad Dudhgaonkar
Allan, the funniest thing about my problem is I have used this provision of setting injection using this model many times before successfully! It asks for the location (coordinates of the point) of the injection plane. From my experience I learnt that this point has to be some where on domain. In order to fulfil this requirement I put a small meshed cylinder (separate from flow domain). It has worked before but now I am getting this error.
Thanks again for your time. Prasad
Old   November 27, 2013, 13:06
misterdd
misterdd is on a distinguished road
try to update your video card driver and run fluent using OpenGL.
misterdd is offline   Reply With Quote
Fluent Access Violation error after a specific iteration number willyCEP FLUENT 11 August 29, 2012 12:10
Fluent 12.0 is worst then Fluent 6.2 herntan FLUENT 5 December 14, 2009 02:57
UDF problem (ACCESS VIOLATION) Jorge Poyatos FLUENT 5 March 16, 2009 08:02
How to import mesh from ICEMCFD to Fluent 6.2 jeevan kumar CFX 5 October 20, 2008 05:41
Linux64 bit for Fluent 6.2 and Core 2 Quad Jerzy Krawczyk FLUENT 5 April 23, 2007 16:38
