How to connect two adjacentr interfaces?
Old   November 27, 2013, 09:25
Default How to connect two adjacentr interfaces?
Pavel Peukert
Paulie is on a distinguished road
I want to simulate a cooling of flowing water inside few parallel tubes and air flows around the two tubes. The mesh is huge and to spare some elements I want connect the 1st tube outlet to the 2nd tube inlet and the 2nd tube outlet to 3rd tube inlet... etc. The ends of the tubes are not adjacent. They lay in one plane but in some distance from each other. Is there a possibility to use correctly an interface boundary or an UDF is necessary? If the usage of an interface is possible please give me a tip how to set it for this case.
Thank you in forward for the help.
P.
PS: I'm sorry for the wrong title, it should be "non adjacent interfaces". I suppose, I canīt change it additionally?
Paulie is offline   Reply With Quote
What type is defined as the interfaces between stator and stator on OF-2.1.1? renyun0511 OpenFOAM Running, Solving & CFD 3 May 18, 2013 08:11
Fluent 13 Interfaces felicemastronzo FLUENT 0 February 22, 2012 02:54
Subdomain or Interfaces (CHT) sandeep_tu CFX 8 July 14, 2009 11:06
connect failed with errno%3d113 wedsall OpenFOAM Running, Solving & CFD 2 November 3, 2008 04:17
grid interfaces kiko FLUENT 0 February 13, 2007 10:28
