Please tell me which is this fluid used in Fluent tutorial |
December 2, 2013, 08:42 |
Sandeep
The following properties of the one fluid has been mentioned in the boiling tutorial available in the Fluent with its liquid and vapor phase;
Liquid phase: density=200 kg/m3, Specific heat=400 j/kg-K, Conductivity=40 W/m-K, Viscosity=0.1 kg/m-s Vapor phase: density=5 kg/m3, Specific heat=200 j/kg-K, Conductivity=1 W/m-K, Viscosity=0.005 kg/m-s I am not able to find out which is this material used in the Fluent boiling tutorial. If anybody know which is this material, please let me know. Thanks in Advance Last edited by Sandip K; December 2, 2013 at 08:51. Reason: After uploading table gets desructed. |
December 2, 2013, 13:48 |
Rep Power: 17 |
send me the tutorial and perhaps will help you.. That sounds like refrigerant
material name |
looking for a smart interface matlab fluent | chary | FLUENT | 24 | June 18, 2021 09:07 |
Fluent Tutorial on Heat transfer | Far | FLUENT | 15 | July 29, 2017 15:31 |
IC engine simulation tutorial by FLUENT | yash | FLUENT | 4 | April 6, 2015 19:44 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 10:54 |
