December 9, 2013, 07:01 |
Fluent Residual Problem
le hoang anh
Rep Power: 13 |
Hi everyone,
I am running my simulation in 3-D Nozzle. I choose K-Omega Low Reynold Turbulence model for turbulence Solution method: SIMPLE, transient time Gradient: Green Gauss Cell base Pressure: Linear Momentum: Second order Upwind(TVD Scheme) Kinetic Turbulent omega equation:First order upwind anll relaxasion value set to 0.8 (referent from book Introduction Finit volume method) But the continuity residua will grow up to 1e+04, and after 100 step the error appare: AMU error. Could you give me sugesion about this problem |
December 9, 2013, 07:57 |
Nazim
Rep Power: 12 |
This error may occur due to bigger mesh sizes try to give smaller mesh size and also check the value of pressure at the reference value section give it as .9 or .8 and try
December 9, 2013, 10:29 |
le hoang anh
Rep Power: 13 |
Thank you for your suggestion, shahid
What do you mean about: pressure referent to .9 or .8 Actually, the big grid size may be one of the reason because Fluent shown the warning about hight ratio in the grid |
December 10, 2013, 00:30 |
Nazim
Rep Power: 12 |
sorry not the pressure the momentum value which we get in the solution controls in fluent. I Dont know exactly what it is but once i got the same error of AMU and when i checked the solution control the momentum value was zero due to which i was getting the error.
Thank You |
December 10, 2013, 00:43 |
Nazim
Rep Power: 12 |
hey leho do you have any idea about the error : Geometry would result in an non-manifold bodies
parallel run is slower than serial run (pimpleFoam) !!! | mechy | OpenFOAM | 18 | August 17, 2016 17:19 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
Why RNGkepsilon model gives floating error | shipman | OpenFOAM Running, Solving & CFD | 3 | September 7, 2013 08:00 |
ForcesCoeffs | ronaldo | OpenFOAM | 4 | September 14, 2009 07:11 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
