Domain not remeshing
Old   December 10, 2013, 08:44
Default Domain not remeshing
adubois is on a distinguished road
Hi all,
I defined a circular shape in a square domain meshed with triangular elements. Now the circular shape is rotating and translating in the square domain (defined using a cg_motion udf, with sinusoidal shape) and I want the grid to be remeshed as soon as the skewness exceeds 0.7 (I also turn on smoothing for the deformation when no remeshing is needed). When I apply the relevant setting in "dynamic mesh" tab and preview the mesh motion, the smooting occurs but no remeshing is taking place even if the max skewness clearly exceeds 0.7. (local cell option is enabled btw)
Anyone suggestions on what might be wrong or where I am defining something wrong?
adubois is offline   Reply With Quote
Old   December 11, 2013, 03:55
Default Additional information
In attachment you can see the domain, the inner domain oscillates in the domain (translate and rotates) but the outer domain becomes very skew after a few iterations so I want to apply remeshing but this is not doing anything ... the remeshing does not seem to "turn on".
Old   May 14, 2014, 10:33
Jochem Grietens
JochemGrietens is on a distinguished road
Hi adubois,
I have the exact same problem, have you had any succes in fixing it ?
JochemGrietens is offline   Reply With Quote
Old   May 14, 2014, 11:07
Yes I have, you should only add the moving boundaries as dynamic mesh zones and not the actual "zones" that should be remeshed (is counter intuitive I know). Is it working now?
Old   May 14, 2014, 14:59
Jochem Grietens
Yes ! it works perfectly now, i would have never found that myself! thank you so much ! strange though !
Old   May 14, 2014, 15:28
No problem man, I was a hunch that made me try that and it worked! If I can help with anything else let me know
Interface between fluid domain and porous domain windhair CFX 6 May 10, 2018 14:26
[ANSYS Meshing] remeshing in Ansys CFX - help or tutorials needed Doginal ANSYS Meshing & Geometry 6 September 24, 2014 09:43
Error (2 isolated fluid regions) with an englobing domain syens CFX 2 January 12, 2012 10:55
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 18:53
