Centrifugal force/ Rotating Wall
Old   July 21, 2002, 21:33
Default Centrifugal force/ Rotating Wall
david
Hi All, When we define a rotating wall, do we have to add the centrifugal force (mw^2r or mv^2/r) to the momemtum equation in Fluent, or she does by herself ??!!
DC
Old   July 22, 2002, 01:40
Default Re: Centrifugal force/ Rotating Wall
Ashu
You need to specify the center of rotation and speed (rad/s). Centrifugal force gets calculated automatically during solution. Ashu
Old   July 22, 2002, 03:57
Laika
Are you sure you need a moving wall, and not a rotating reference frame?
The first is a boundary-condition. It applies a shear stress on the fluid at the wall. The second is a real moving zone you must assign to the entire fluid zone.
You can obtain the same results, but the moving wall simulation migth take longer to converge than the moving reference-simulation.
If your wall has in it's movement a component perpendicular to its surface, the shear-stress-formulation of the moving wall is incomplete to describe your problem. In that case the moving reference-frame is the only correct way.
Laika, still orbiting
Old   December 6, 2013, 01:46
Shatrughan Jaiswal
s.jaiswal is on a distinguished road
Originally Posted by Ashu
;101852
Hi friends,
My problem related to providing centrifugal force while giving a constant rotation to the body which is a square cavity filled with water. Meshing is done by the use of Gambit and simulation is to be performed in Ansys fluent.
The cavity is rotated with the origin of itself.
I want to know how the centrifugal force can be provided in the fluent.
Is there any UDF in the momentum source is required to define the centrifugal force?
Please let me know.
s.jaiswal is offline   Reply With Quote
Old   January 2, 2014, 06:30
Shatrughan Jaiswal
thanks for your reply!!
UDF for defining a body force in Singel ROtating Reference Frame teymourj Fluent UDF and Scheme Programming 9 August 18, 2016 15:33
cyclone separator- centrifugal force kumar FLUENT 2 May 29, 2008 03:33
Difference b/t rotating wall and rotating domain? Juno Kim CFX 2 February 20, 2007 20:08
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
rotating wall eric FLUENT 8 September 20, 2003 17:49
