Simultaneous fine and course Meshes for two parts of a solver
Old   December 26, 2013, 01:51
Default Simultaneous fine and course Meshes for two parts of a solver
Masoud Ami
MasAmi is on a distinguished road
Hello All.
I want to simulate turbulent mixed convection flow and Radiation heat transfer in a vertical parallel plates channel.
Does anyone know that how we can set different meshes for these two parts in ANSYS? I mean because radiation doesn't need a very fine mesh, can we set a course mesh for solving RTE(radiation transfer equation) and at the same time a fine mesh for flow part?
As you may know, after each iteration in RTE solution, result goes to energy equation via source term. Then the flow equations are solved for one iteration and this procedure goes on.
Best Regards,
Mas
MasAmi is offline   Reply With Quote
