Eulerian Granular flow:receive reverse flow and solution isn't converge
Old   May 12, 2013, 01:46
Default Eulerian Granular flow:receive reverse flow and solution isn't converge
bahman is on a distinguished road
Hi all friends
I want to modeling steady state two-phase flow of liquid - solid using Eulerian-Granular approach in Fluent but when I do it,I receive Reverse flow in pressure inlet and outlet message (my BCs are pressure inlet&outlet) and solution isn't converge.
A two-dimensional (2-D) axisymmetric model was created and meshed with Gambit as shown in attach picture.
multiphase particulate (volume fraction= 0.2) fluid was pumped into the main model inlet (with pressure inlet=13.8Mpa), and mingled with multiphase particulate (volume fraction = 0.8) fluid was pushed from the bottom inlet(pressure inlet=13.8Mpa) then flow to outlet(pressure outlet=10.3Mpa).
I've tried both steady and unsteady state with different URF but solution isn't converge.
particle diameter:45e-6 m
particle density:2350 kg/m3
fluid density:1000 kg/m3
solid fluid interaction:syamlal o'brien
Assuming a wall boundary instead of the porous medium and drill string/pipe is wall BC in domain.
please guide me
Regards
bahman is offline   Reply With Quote
Old   January 2, 2014, 11:53
Default steady-state granular flow
Kanarya is on a distinguished road
did you manage to solve the problem because I have the same problem.
thanks in advance!
Best!
Originally Posted by bahman View Post
Hi all friends
please guide me
Regards
Kanarya is offline   Reply With Quote
Reverse flow warning and solution divergence SH_P FLUENT 0 May 27, 2012 15:26
Reverse flow starting when about to converge Ananthakrishnan FLUENT 4 May 24, 2012 03:36
Periodic boundary conditions in 3D Eulerian granular flow simulations dsm FLUENT 4 March 2, 2012 19:04
suggest solution for reverse flow alimoddin FLUENT 2 January 23, 2012 13:59
Eulerian Granular Flow daninwin FLUENT 1 October 10, 2002 08:11
