Fluent failed to start
Old   June 15, 2016, 10:07
Default Fluent failed to start
Tazo Jorbenadze
tj1972 is on a distinguished road
I'm not Fluent frequent user (primarily CFX) but this time need Fluent for some task.
But, the problem is that Fluent does not want to start neither from workbench nor directly thru .exe file.
It reports "Fluent application failed to start" and that's it - no more information.
Found some recommendations on the internet but none of them works (like turning off UAC, IPv6, updating some drivers, etc.).
I believe fresh install will solve problem but don't have time doing so (takes long).
May be you know the solution for this problem.
I speak about ANSYS 17.1, Windows 7x64 with all latest updates in place.
Thank you for your help.
tj1972 is offline   Reply With Quote
Old   June 17, 2016, 07:16
Tazo Jorbenadze
So, seems I'm the one in whole CFD world who has this stupid problem with Fluent?...
Great...
Old   July 2, 2016, 20:08
Fadi hajj
Fadih is on a distinguished road
Hello sir,
I am having the same exact problem.
Whenever i run a simulation on fluent then save and exit, i get back to it and double click the solution but says the application fluent failed to start.
Did you find a solution?
Thank you,
Fadi
Fadih is offline   Reply With Quote
Old   December 27, 2016, 23:11
Zhengyu Qu
hntter is on a distinguished road
I have the same problem like you and I did nothing because it was running the last day and the next day Fluent cannot start neither from workbench nor directly.
Does anyone know how to solve? Reinstall the current or the advanced version of workbench does not help at all.
hntter is offline   Reply With Quote
How to start Fluent with Matlab?? Jay Hu FLUENT 8 November 9, 2022 06:30
fluent performance degradation: sched_setaffinity() call failed puneet336 FLUENT 4 October 27, 2018 15:17
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 02:00
Initial conditions for uniform flow andreas OpenFOAM 5 November 16, 2012 15:00
[OpenFOAM] ParaView/Parafoam error when making animation Disco_Caine ParaView 6 September 28, 2010 09:54
