September 18, 2014, 23:43 |
#21 | |
Lucky
Rep Power: 66 |
September 19, 2014, 09:50 |
#22 | |
Rep Power: 17 |
Hi Guys,
Sorry for the slow reply. To clarify my understanding (based on what was said on the ANSYS webinars), actually you can use SIMPLE with the GPU, and the calculations WILL take place on the GPU. However, the issue is: 1) GPU are designed for computing LARGE matrices quickly, so dealing with (solving) the large pressure + velocity coupled matrix will give the best speedups. 2) The major bottle neck with GPU computing at this stage, is the speed at which information gets onto and off of the GPU. i.e. how fast data gets through the PCI-Express bus into the GPU from the CPU. If you solve in a segregated fashion, i.e. using SIMPLE, the time overhead of getting info on and off of the GPU overcomes the time saving from the matrix solution. So its better to move a big lot of data onto the GPU, solve and move it off with GPU computing, rather than move lots of smaller packets of data on and off the gpu (i.e. x3 times min for SIMPLE vs x1 for COUPLED). This is my understanding, hope it helps, cheers jonathan Quote:
September 21, 2014, 21:58 |
#23 | |
Kimi
Rep Power: 13 |
September 21, 2014, 22:18 |
#24 | |
Kimi
Rep Power: 13 |
During my experiment using GPU calculation with SIMPLE/COUPLED scheme in Fluent, once '-gpgpu=1' is called, the fluent process can be found on GPU card (by monitor command provided by nvidia). This seems to be agreed with your point. On the other hand, speedup gained by gpgpu with COUPLED scheme compared to that with SIMPLE scheme goes the other way. Five cases for test are prepared, and here is what I tested with/without gpu for each case: a) use SIMPLE scheme b) use COUPLED scheme The results? Solving time with GPU is almost equivalent to that without GPU under scenario a), i.e with SIMPLE scheme (which is the case as you described). But with COUPLED scheme, time with GPU increases in an unexpected way which is fairly longer than solving time with CPU only (which is the case as you mentioned at the very start of this post). Is there anything inappropriate in my test procedure? Have you found way to solve this? Thanks a lot. |
January 24, 2016, 09:15 |
MultiPhase Flow using K80
#25 |
B_Kia
Rep Power: 11 |
Hi Experts, i am going to model a propeller in Fluent, half of it is under water and half of it in air so the problem is multiphase. i am going to solve the problem using GPU to show how GPU can accelerate solving. The workstation i am going to use has 4*Xeon E5-4669 v3 + Nvidia Tesla K80. i am asking is it possible to model such a problem using GPU or not ? and advice will be appreciated.
coupled solver, fluent, gpu, pbns, v15 |
GPU acceleration on ANSYS Fluent 14.5 | Daveo643 | FLUENT | 20 | April 28, 2018 13:50 |
Using GPUs with UDFs | TMac | Fluent UDF and Scheme Programming | 1 | January 11, 2013 12:24 |
DELL Tested Acceleration of OpenFOAM using GPUs | Lukasz | OpenFOAM Running, Solving & CFD | 0 | September 17, 2012 16:32 |
Is it possible to speed up FLUENT by: NVIDIA Tesla GPUs | czaru | Hardware | 0 | November 18, 2011 04:33 |
Will GPU's play a part in the future of CFD? | Tom | Main CFD Forum | 15 | January 22, 2009 05:04 |
