Question about Fluent monitor and input parameter
Old   January 27, 2014, 04:30
Question Question about Fluent monitor and input parameter
Anna Tian's Avatar
Meimei Wang
Anna Tian is on a distinguished road
Two questions:
1. How to set tan(15 degrees) as the value of the input parameter? Fluent tells that it only accept a real value. CFX can do this easily. So I guess there should be a way for Fluent to do this.
2. I'd like to set a input parameter as a force vector in the Fluent monitor. But fluent also doesn't accept it. May I ask how to set it?
Best regards,
Meimei
Anna Tian is offline   Reply With Quote
Old   January 27, 2014, 18:15
Andrew Kokemoor
Kokemoor is on a distinguished road
1.) As far as I know, Fluent isn't able to do this directly, but Workbench can. You can define your input parameter in Fluent, then go back to Workbench and give it an expression rather than a value. This can also be a function of other parameters.
2.) I'm not sure about this, besides the possibly inconvenient solution to calculate it yourself from the components after the fact.
Kokemoor is offline   Reply With Quote
Old   January 28, 2014, 02:12
blackmask will become famous soon enough
If you use TUI (text user interface) you could use scheme to do that.
> (define rad (lambda (x) (* (atan 1) (/ x 45))))
> (define tand (lambda (x) (tan (rad x))))
> (tand 15)
0.26794919
blackmask is offline   Reply With Quote
Old   March 19, 2015, 08:32
Question
Pierre
Pierre1 is on a distinguished road
I tried Workbench to achieve this. But I'm still not able to give any expression to Force Vector as indicated in the attached figure.
Pierre1 is offline   Reply With Quote
Old   March 19, 2015, 09:43
Andrew Kokemoor
My suggestion would be to create multiple output parameters from Fluent, one for each coordinate direction (F_X, F_Y, F_Z), then create another parameter in Workbench that calculates the vector in the desired direction from those components. e.g. in 2D, F_X*cos(theta)+F_Y*sin(theta), where theta is another input parameter.
Old   March 19, 2015, 09:49
Pierre
I see. So you compute the vectors all in Workbench.
Old   March 19, 2015, 10:17
Andrew Kokemoor
Yeah, I think that's probably the simplest way. I'm pretty sure you could do it in scheme, maybe even in a single output parameter, but doing it in Workbench would be straightforward and reliable.
