January 28, 2014, 10:26 |
outlet
mariana
Rep Power: 12 |
hello guys,
i would like to ask you something. my question may be stupid but i still need to know. so i am working in fluent and i have one pipe, i put velocity (that it starts from inlet) but i haven't seen the option for the outlet. what can fluent has as default? because i need to make the situation that water( or another fluid) is going out. how can i do it? thank you very much br Marianna |
January 28, 2014, 19:18 |
You should make one pipe end to be inlet (velocity inlet, pressure inlet, or whatever appropriate) and the other outlet (pressure outlet, outflow, etc.). The default b.c. would be wall, and you won't see much fluid flowing if you have one pipe end inlet and the other walls.
January 29, 2014, 04:45 |
Simas
Rep Power: 14 |
As I see you don't have much experience in this for beginning just try velocity-inlet and outflow. It is easiest options.
In Velocity-inlet input speed and in outflow don't change anything. |
January 29, 2014, 05:51 |
hello Blackmask and Zombiaska!
mariana
Rep Power: 12 |
First of all thank you for replying.
as you understood i am new in the club and i do not know fluent well. p.s. i know that it is stupid but i cannot find the option outflow. i put inlet velocity and pressure and for outlet there is only the option for pressure, for water there is nothing. thank you again Marianna |
Strange Results at Tank Outlet with InterFoam | mgdenno | OpenFOAM | 18 | November 28, 2019 23:05 |
Pressure Outlet Guage pressure | Mohsin | FLUENT | 36 | April 29, 2016 17:16 |
Compressible flow, no data at the outlet | mireis | FLUENT | 6 | September 3, 2015 02:10 |
VOF Outlet boundary condition in cfd - ace | JM | Main CFD Forum | 0 | December 15, 2006 08:07 |
Impinging Jet. Outlet Boundary Condition | Vincent | Main CFD Forum | 0 | December 16, 2003 10:49 |
