Fluent setup to determine fan performance
Old   August 31, 2005, 20:16
Default Fluent setup to determine fan performance
afaik
Hi, my problem is to use fluent to determine a fan charateristic curve (flow rate vs static pressure) for a specific fan (exhuast fan). I have used GAMBIT to create a 1/6th section of the fan, which comprises one blade of the fan... I want to use the unsteady solver/moving mesh options in FLUENT... I also plan to use grid-interfaces between fluid volumes (fan to duct, etc)... how would I set up the problem and boundary conditions to solve for a number of flow rates and determine the static pressure rise in each case.
Old   September 1, 2005, 07:01
Default Re: Fluent setup to determine fan performance
srinivasan
hi, i did my M.E project , determining the fan characteristic curve using CFD. urs srinivasan
Old   September 2, 2005, 05:20
Moke
I am also interested in a similar thing. How did you do that srinivasan?
Moke
Old   September 5, 2005, 01:44
afaik
Hi srinivasan, that sounds exactly what I want to do, any pointers??
Moke, how much have you looked into this problem?? Maybe we can offer each other the solution.
Old   October 23, 2009, 12:39
Default To Srinivasan
tengra is on a distinguished road
Originally Posted by srinivasan
;123847
Could you reply me to my email at munni29@yahoo.com. I need some help in the fan curve simulation.
Thanks.
Munni
tengra is offline   Reply With Quote
Old   August 1, 2014, 04:27
Default Fan curve problem
hashim chaudhry
chaudhry_hashim is on a distinguished road
Send a message via Skype™ to chaudhry_hashim
Hi I am quite new to CFD i am trying to find out the fan curve what did uptill now I made inlet duct 15 times of fan dia with pressure inlet (0.0 Pa), outlet duct 30 times of fan dia with pressure outlet (0.0 Pa) and I am giving fixed rpm to the rotating region in between. I am measuring pressure in inlet and outlet duct at a position 10 times of fan dia. but Still I didnt find the relevant pressure difference across the fan and also the solution is not converges
I would be very grateful if you people help me out
chaudhry_hashim is offline   Reply With Quote
Fan settings in fluent fluent_beginner FLUENT 7 February 23, 2012 22:13
fan function in fluent vikasmeche FLUENT 0 June 12, 2009 03:37
Parallel performance OpenFoam Vs Fluent prapanj Main CFD Forum 0 March 26, 2009 05:43
hyperthreading and FLUENT performance sb FLUENT 1 March 25, 2007 06:06
fan performance based on blade shape balaji Main CFD Forum 1 September 16, 2005 11:56
