reverse flow at pressure inlet affecting solution
Old   February 7, 2014, 02:09
Default reverse flow at pressure inlet affecting solution
Virendrasingh Pawar
virendra_p is on a distinguished road
hi friends,
i am modelling a standard pump sump problem using fluent. i am using VOF model for multiphase and ke-relizable for viscous formulation. gravity and buoyant formulation is enabled. plz see the pic attached for problem description. the top surface of air domain is defined as pressure inlet..i am running a transient simulation and keep getting reverse flow error at the pressure inlet...this is affecting my solution in a way that the streamlines on the interface of air and water enter the air domain...as far as know this should not happen!.....please give me some suggestions...
thanks in advance. have a good day
virendra_p is offline   Reply With Quote
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 05:37
reversed flow at pressure inlet and turbulent viscosity is limited.... cfdiscool FLUENT 10 June 10, 2015 06:15
Reversed flow in pressure inlet lehoanganh07 FLUENT 5 January 19, 2014 18:35
Why we normally provide velocity at inlet and pressure at outlet for pipe flow? p07ip705 Main CFD Forum 3 August 3, 2012 05:53
Mass Flow Inlet Pravir Kumar Rai FLUENT 0 February 17, 2003 19:23
