need help about UDS & VOF
Old   April 8, 2010, 05:41
Question need help about UDS & VOF
mengyue
mengyue1 is on a distinguished road
hi guys, i am simulating a system, the fluid involved in this system is water,water vapor and air, because of gradient of vapor mass fraction, there exists phase change.
i don't plan to use the species model available in FLUENT, in my model, i define there phases, which are water,vapor(phase-3) and air, and also, i introduce a UDS to model the diffusion of vapor in the air, the scalar is vapor mass fraction, is that right?
I define the uds for phase-3, and i think i need define vapor/air diffusivity for this uds. but now i am confused with it. in the material pannel, each material has a "UDS Diffusivity", and which one i should introduce my udf for diffusivity? when i introduce udf to vapor, there are some error tips in FLUENT:
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: ()
but when i define the same udf for other materials(air and water), there are not errors.
Can someone tell me the reason... i think my udf should define for vapor, not the other materials...
Regards!
PS:the code is:
DEFINE_DIFFUSIVITY(diffusivity, cell, third, i)
Thread *mix_th, *sec_th;
real diff;
real v;
mix_th = THREAD_SUPER_THREAD(third);
sec_th = THREAD_SUB_THREAD(mix_th, 1);
if ((C_VOF(cell, sec_th)==1))
diff = 0.0;
else
diff = 3.02761*pow(10.0,-5.0)*C_MU_EFF(cell, mix_th);
return diff;
mengyue1 is offline   Reply With Quote
Old   April 8, 2010, 08:48
mengyue
Dose anyone help me? thanks...and where is sega?
Old   April 9, 2010, 00:09
mengyue
Dose anyone help me? Thanks....
Old   April 9, 2010, 06:39
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
sega is here!
But I think I'm not use here ...
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   April 13, 2010, 21:44
mengyue
Oh, well, thanks all the same。。。
Originally Posted by sega View Post
sega is here!
Old   April 12, 2012, 09:59
Igor
DaddySpeleo is on a distinguished road
I solved such problem by this way:
1. Make UDM containing the data gotten via C_VOF.
Simle cycle C_UDMI(...)=C_VOF(...)
2. Remove C_VOF(...) from DEFINE_DIFFUSIVITY
3. Use data from UDM in DEFINE_DIFFUSIVITY.
It seems to me - this error appears in some cases when macros C_VOF try to work. For example in solid area.
Best regards...
DaddySpeleo is offline   Reply With Quote
Old   February 7, 2014, 09:51
Kanarya is on a distinguished road
hi,
did you manage to solve the problem...I have the same problem as you.
thanks for your help in advance!
Kanarya is offline   Reply With Quote
Old   February 7, 2014, 17:40
Igor
I didn't try to do smth more exept described above method - this method works.
May be Fluent 15 is better?
Best regards!
VOF Inlet condition Rizwan FLUENT 15 July 5, 2018 16:33
UDF Defining VOF Free Surface at Outlet Alex Fluent UDF and Scheme Programming 13 August 8, 2012 16:50
Doubts UDS Flux, UDS Unsteady for VOF model kel85uk FLUENT 0 March 17, 2010 08:53
Associating profile files for the UDS though a UDF Bharath FLUENT 0 December 1, 2006 15:58
Difficult BCs about Freesurface Simulation by VOF Yongguang Cheng FLUENT 0 September 19, 2003 07:39
