Pressure_Inlet with constant inlet velocity?
Old   February 6, 2014, 09:55
Default Pressure_Inlet with constant inlet velocity?
Sandra_ is on a distinguished road
I am running many simulations, using different values for the boundary 'pressure_inlet' . I want the inlet axial velocity to have the same value for all simulations. How can I realize this?
pleeeeaaase help me!
regards
Sandra
Sandra_ is offline   Reply With Quote
Old   February 6, 2014, 13:04
Gonzalo
gfoam is on a distinguished road
Can you specify what kind of simulation are you trying to do? Compressible or incompressible? What geometry? But in the case of pressure inlet you specify a stagnation or total pressure an a static pressure (and if your problem is compressible then you must set the total pressure), the the flow conditions at inlet are computed with the isentropic formulations. But if you want more detail, please read the chapter 6 of FLUENT's User Guide
gfoam is offline   Reply With Quote
Old   February 7, 2014, 09:40
Default Thanks
Hello gfoam,
thank you for your answer!
A pressure-based flow is running through a simple sharp edged orifice. I am using a multiphase and a cavitation model. Standard k-epsilon turbulence model and wall function.
I specify a gauge total pressure and the supersonic/initial gauge pressure, normal to boundary . (actually I copied all settings from the tutorial: modeling cavitation).
When I check on my results the gauge total pressure I entered is the static pressure at the inlet. The supersonic/initial gauge pressure I set to zero because it has no influence on the intial velocity. I tried different values and always got the same values for the velocity.
I don't know how I can specify a constant inlet velocity (without using a velocity inlet boundary) for all my simulations.
Old   February 8, 2014, 14:26
Is it even possible to specify a value for the inlet velocity, using a pressure_inlet and pressure_outlet boundary condition?
If I write a UDF or a Profile it's only possible to use then when I have a velocity_inlet boundary condition.
Any help? Pleaase
Old   February 8, 2014, 14:29
I also tried to patch it during the initialization but it didn't work either..
Old   February 10, 2014, 05:56
Gonzalo
OK, acording to th User's Guide when you specify a Pressure Inlet BC, in subsonic flow you have to set the total perssure and a initial gauge pressure, so as you can see the initial condition is only used to initialize the flow (§6.3.3.1.1.4. Defining Static Pressure of User's Guide). So if you can change the velocity of your simulation, you must change tho outlet pressure, but you can't calculate in advance what velocity you get at the inlet, that's why if you want to specify the velocity at the inlet you must use Velocity Inlet BC's. I hope this helps you. Regards.
Gonzalo
Simulation of radial gas turbine, Inlet velocity components dmaz CFX 17 May 19, 2019 09:45
velocity inlet and ideal gas simultaneously-what's wrong? preetam69 FLUENT 0 September 28, 2013 04:51
User Defined Profiles, Swirl, Velocity Inlet saurus FLUENT 0 January 26, 2011 15:35
UDF problem : inlet velocity in cyl. coord. system Jongdae Kim FLUENT 0 June 15, 2004 11:21
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
