February 18, 2014, 08:50 |
Fluent Help Needed please
ahmed ibraheem
Rep Power: 12 |
I have problem in two phase flow ( oil-water ) through a horizontal pipe
I want measure the pressure drop (two point) on pipe length , no problem in this point , my problem i can not see type of flow for example stratified flow or wavy stratified flow and Y plus . properties my case density of oil 828 kg/m3 and viscosity 0.0055 pa .s density of water 998.2 kg/m3 and viscosity 0.001003 pa .s surface tension between them 0.0396 N. m diameter of pipe 0.014 m length of pipe 3.5 m velocity of water 0.6 m/s velocity of oil 0.09 m/s mixture velocity is 0.69 m/s water volume of friction is 87 % P1 at 2.5 m P2 at 3.2 m VOF model use and k-e model in future I want change properties ( diameter and velocity an length .....) what your suggestion and implement for my case thank you ahmedsh974@gmail.com |
February 18, 2014, 12:21 |
François Grégoire
Rep Power: 17 |
when you have solved your problem please send it to me with a detailed report: iwonfifteenolympicmedals@hotmail.com
[waves2Foam] Waves2Foam Related Topics | ngj | OpenFOAM Community Contributions | 660 | August 20, 2018 12:39 |
Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 10:54 |
Urgent Help Needed!!! (regarding FLUENT UDF) | dsen | FLUENT | 2 | May 28, 2010 13:36 |
Fluent error help needed | Praveen | FLUENT | 0 | July 3, 2006 00:56 |
"Memory too low" problem with Fluent HELP NEEDED | Amr | FLUENT | 6 | May 8, 2006 12:06 |
