March 12, 2019, 01:12 |
Compressible Flow Through Rocket Nozzle
Marcin
Hello everyone,
I am working on a project to design a hybrid rocket engine. I am having some difficulties with simulation compressible flow through the nozzle. I have a 2D surface imported from SolidWorks which includes the axis-symmetric nozzle and a large air domain. I am using ANSYS 19 with a student license. Energy Equation is on Viscous Model is K-Omega & SST The working fluid is air Density is ideal-gas Cp -> Piecewise-Polynomial Viscosity -> Sutherland -> 3 Coefficient Method Cell Zone Cond's -> Set to 0 Pa Boundary Conditions: inlet -> Pressure Inlet Gauge Total Pressure -> 1896100 Pa Initial Gauge PRessure -> 1895900 Pa Thermal -> 3394.32K outlet -> Pressure Outlet Gauge Pressure -> 0.6 Pa (Mars surface pressure) Thermal -> 350K Reference Values -> Compute from inlet The results are a little troubling. The velocity magnitude is good and the Mach contours also seem reasonable but the temperature contours don't make sense. I have a region of very gold gas that develops well within the nozzle. The static pressure contours are also wrong. I have reasonable pressure in the subsonic portion of the nozzle but everything past the throat and into the air domain is a uniform low pressure. Additionally, should I be looking at static pressure or one of the other pressure options? I apologize for the wall of text but any and all feedback will really be appreciated. Thanks a lot! imgur link with screen shots of my results |
March 12, 2019, 02:15 |
Alexander
Rep Power: 34 |
youtube -> rocket nozzle ansys fluent ->
https://www.youtube.com/watch?v=oY_3_c0rDiw spent time: 15 sec best regards |
March 12, 2019, 09:42 |
Marcin
Thanks for the quick response. I'll try modifying the parameters according to this video although I'm not sure what the issue is with how I've set up my simulation so far. The velocity plot looks pretty good; it's Just the temperature and pressure plots that are giving me issues.
Are you saying it only took you 15 seconds to find that video? Yes, I'm sure it's easy to find something when you already know what you're looking for. EDIT: Corrected formatting |
CFD Simulation of a Rocket Engine Nozzle: Divergence Issue (Want to see nozzle plume) | VinayakDesh | FLUENT | 4 | February 2, 2022 20:57 |
Cavitation in compressible flow | soni7007 | CFX | 3 | March 29, 2013 12:06 |
nozzle flow for a solid propellant rocket | ilperalta | FLUENT | 0 | April 26, 2011 10:48 |
Flow simulation in a Pelton turbine nozzle | fivos | FLUENT | 0 | April 19, 2011 11:46 |
Axisymmetirc Compressible Flow in a C/c and Nozzle | Nauman | FLUENT | 0 | December 21, 2004 07:40 |
