Non-premixed combustion: local heat release rate |
September 3, 2007, 12:58 |
Hi I was was wondering how the local heat release rate is calculated in Fluent??? I know in FDS it is computed by "first locating the flame sheet, then computing the local heat release rate per unit area, and finally distributing this to the grid cells that cut the flame sheet, so the infintesimally thin flame sheet is smeared out over the width of the cell"
Is Fluent the same? Thanks in advance for your help! |
April 28, 2021, 22:11 |
simulating combustion noise by hybrid method
chenjingzhen
Rep Power: 5 |
Hi, have you solved the problem? can you please tell me how do you calculate the heat release rate(or define the custom field function) in fluent?
I deeply need the data on the heat release rate!! sincerely thank you
Love is the best gift to others |
heat release rate calculation | Karthick .K | FLUENT | 2 | April 28, 2021 22:15 |
combustion model in premixed combustion chamber | wuyu | FLUENT | 9 | February 16, 2018 10:40 |
rate exponent for combustion modeling.. | palani kumar | FLUENT | 5 | May 17, 2016 03:27 |
heat release rate in output file | Caty | CFX | 6 | June 16, 2014 11:06 |
Help on premixed combustion heat | seaspace | Main CFD Forum | 2 | May 27, 2003 05:28 |
