March 7, 2014, 06:58 |
Simple piston modelling with dynamic mesh
Michael Hilton
Rep Power: 12 |
I have designed the cylinder which has a shallow dish piston head which moves from TDC to BDC. This motion works correct however when it reaches BDC the motion stops and doesn't travel back to TDC despite the crank angle increasing.
I have the top of the piston set as stationary and the piston head as rigid body with *piston full* profile. It is also set for smoothing and layering with the in-cylinder option on. Can anyone help please? Thanks Michael |
March 7, 2014, 12:04 |
Michael Hilton
Rep Power: 12 |
I have managed to find a solution to this.
can anyone tell me how to select a region on the mesh and seperate it to create another cell zone to use as the inlet for the fuel? I have tried using adapt-region to select an area then using mesh-seperate-cells but the area isn't being created. Using ansys 14.5 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Dynamic Mesh on Pintle type injector. | herntan | FLUENT | 16 | September 4, 2020 08:27 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Dynamic Mesh for Movement of Piston | vigii | FLUENT | 0 | November 15, 2013 05:45 |
Cannot preview the dynamic mesh | sam | FLUENT | 4 | May 26, 2005 06:58 |
