Help Needed for very simple problem {ANSYS Fluent}
Old   March 12, 2014, 08:21
Post Help Needed for very simple problem {ANSYS Fluent}
naikaj is on a distinguished road
Hi all,
I'm a final year mechanical engineering student and have taken up a project which involves analysis of a simple "rotor in a pipe" situation. I have modeled the rotor and the pipe in Pro E 5.0 and am able to mesh it in ANSYS workbench. Now i'm stuck. I don't know how to set the rotor in motion using the flow. I need to calculate the pressure drop across the rotor and its rotational speed from the analysis. I have the input parameters of mass flow rate and inlet pressure. can someone please guide me through the whole process of setting up the problem in FLUENT in a step by step manner, as i am a beginner.
Thanks a million.
naikaj is offline   Reply With Quote
Old   March 12, 2014, 16:04
Rafal
vekh is on a distinguished road
As You are beginner start from Fluent tutorials. You can also check informations from imechanica etc. like that one: http://imechanica.org/files/fluent_1...ving-parts.pdf
vekh is offline   Reply With Quote
Old   March 13, 2014, 00:35
Thanks! will check it out!
ansys, beginner, fluent, new to cfd
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 03:34
Interesting problem: Parallel Processor VOF Fluent + Dynamic Mesh + System Coupling spaceprop FLUENT 5 September 2, 2014 09:43
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 05:29
FLUENT to ANSYS Temperature Mapping Procedure schreiberc1 FLUENT 0 June 29, 2006 13:50
"Memory too low" problem with Fluent HELP NEEDED Amr FLUENT 6 May 8, 2006 12:06
