Semi circular tubes inlet/outlet boundary condition in a fluid domain in FLUENT |
June 28, 2016, 03:16 |
Onur Özcan
Rep Power: 12 |
Hi all,
I just want to learn about inlet/outlet hydraulic diamaters For example I have a value in inlet in tubes-enter to be obtained by myself numerically.( velocity magnitude depending on volumetric flow rate and tube inlet crossectional areas.) But the model that is used in FLUENT has lots of semi circular tubes then, velocity magnitude depending on volumetric flow rate changes with hydraulic diameter or total circular diamater? I have made 4x Area / Perimeter to find hyrdaulic diamater in a tube. is it correct ? Kind Regards, |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
CFX fails to calculate a diffuser pipe flow | shenying0710 | CFX | 7 | March 26, 2013 04:13 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 06:18 |
