heat exchanger with perforated fins ... help
Old   April 18, 2014, 12:36
Unhappy heat exchanger with perforated fins ... help
ayad's Avatar
ayad
ayad is on a distinguished road
Hi
I have cross flow finned tube heat exchanger with perforated annular fins as shown below.
http://s10.postimg.org/hhq4dfxih/Sna...BIT_Solver.png
after finishing the mesh and geometry and applied boundary condition by using GAMBIT i had exporting the case to fluent.
the problem, there is no connection between the duct and heat exchanger, in the other word the air doesn't collide with finned tube, so there is no stagnation and heat transfer.
Notes
1- constant temp. B.C applied to inner diameter of the pipe
2- the true result must be as shown in fig. below
http://s10.postimg.org/w9uu4s3ft/perforated_fin.jpg
ayad is offline   Reply With Quote
Old   April 21, 2014, 08:04
ayad's Avatar
ayad
Really need help
Old   April 21, 2014, 22:37
Real Name :)
ComputerGuy is on a distinguished road
Sounds like you didn't subtract the inner part from the outer enclosure. Gambit won't automatically subtract the two in a boolean manner just because you set the boundary conditions appropriately. I would check your order of operations or, worst-case, post your journal file for us to review.
ComputerGuy
ComputerGuy is offline   Reply With Quote
Old   April 22, 2014, 09:21
ayad's Avatar
ayad
thank u for your reply
subtract doesn't used here because i have no smooth pipe. I thing split volume must be used in my case. I used volume option to split the two volumes, Bidirectional and
connected options were selected, Retain option was unselected. is this right way please?
Old   April 22, 2014, 13:14
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
You need a Solid volume part and a FLUID volume. You need to ask how to do that in the meshing and the geometry section under the GAMBIT section.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   April 22, 2014, 13:28
ayad's Avatar
ayad
right
I do that, but there is no connection between (fluid and solid) volumes
I think the true result gained by use true method to split the two volumes.
Old   April 22, 2014, 13:36
diamondx's Avatar
Ghazlani M. Ali
of course between SOLID and FLUID, you need walls. I have no idea how to setup a mesh using GAMBIT... I wish i could help more
Regards,
Ali
Old   April 22, 2014, 13:42
ayad's Avatar
ayad
Never mind, thank u so much
Old   April 28, 2014, 01:36
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Notes
can you post a picture of your problem for comparing with your perforated_fin.jpg
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   April 28, 2014, 03:02
ayad's Avatar
ayad
Hi max thank u for your reply
As you see there is no temp. variation in the air temp.
Old   April 28, 2014, 03:06
-mAx-'s Avatar
Maxime Perelli
I never did such computation, but I assume you have to handle thermal conduction within thin wall
check here:
https://www.sharcnet.ca/Software/Flu...e253.htm#33023
Old   April 28, 2014, 03:28
ayad's Avatar
ayad
Indeed i have select the Coupled option B.C. in the fluent .
I think the problem in the gambit, because there is no connection between the pipe and the duct. any method make a stagnation between fins and air will be solve the problem.
Old   April 28, 2014, 03:38
-mAx-'s Avatar
Maxime Perelli
do you have "shadow" walls?
Old   April 28, 2014, 03:41
ayad's Avatar
ayad
Yes, I have.
Old   April 28, 2014, 03:46
-mAx-'s Avatar
Maxime Perelli
are you coupling the good surface with its shadow surface?
if I see your picture you at least need 5 coupling
Old   April 28, 2014, 03:51
ayad's Avatar
ayad
No, I didn't do that.
Old   April 28, 2014, 03:54
-mAx-'s Avatar
Maxime Perelli
then what did you do?
display the list of your bc (wall and shadow) and explain what you did
Old   April 28, 2014, 04:19
ayad's Avatar
ayad
firstly i specified two zones fluid zone (duct), and solid zone (pipe and fin).
then,
inter: fin surface area (coupled B.C.)
P: duct outlet (pressure outlet B.C)
S: Inner diam. of the pipe (constant temp. B.C.)
V: duct inlet (velocity inlet B.C)
WS: 4 wall of the duct
wall: I dont know why is appear
Old   April 28, 2014, 04:27
-mAx-'s Avatar
Maxime Perelli
*wall contains all outer surfaces on which you didn't set any BC, and Gambit set them automatically as wall
ok, now display the BC on inter and inter:012
and show me its geometry
(how did you set the BC? did you pick inter and inter:012 or only inter, then inter:012?)
Old   April 28, 2014, 04:47
ayad's Avatar
ayad
thank you for your time,and I'm sorry for delay, there is a problem in fluent because i connect the computer with internet, So i can't take a picture.
But, the fin and pipe surface area are the geometry of inter.
only inter gave B.C (coupled), and i had neglect inter:012.
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Heat transfer from a heated plate using fins pathakamit FLUENT 1 April 30, 2013 04:07
[ICEM] heat exchanger, too much fins diamondx ANSYS Meshing & Geometry 11 September 24, 2012 19:21
UDF for Heat Exchanger model francois louw FLUENT 2 July 16, 2010 02:21
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
