Reading torque of a disk in post-processor
Old   April 29, 2014, 08:47
Default Reading torque of a disk in post-processor
AH
visitor is on a distinguished road
Dear sirs
I have managed to read torque of a wheel rotated by a fluid entering the turbine casing.
But when copied the turbine, example copied turbine A into another turbine eg turbine B. With the outlet of turbine A connected to the inlet of turbine B, turbine B (wheel B) did not give a torque reading.
The fluid flow did follow path starting from inlet of turbine A, across wheel A, then out of A and towards turbine B. fluid crossing wheel B and then out.
Is there something I should have done when used the Pattern tool to copy turbine A?
The post processor does show Wheel1.trg, and Wheel2.trg, which are the two solid wheel bodies.
Any tips anyone please?
visitor is offline   Reply With Quote
Old   May 7, 2014, 06:03
AH
Just tried to adjust the co-ordinates to match rotating wheels co-ordinates in the mesh-motion menu. Still no torque captured in the post-processor.
Old   May 18, 2014, 00:41
AH
Just FYI, entered the coordinates from the mesh modeler. Select body>Properties, and then found xyz coordinates.
In the post-processor, was able to read torque on disk.src, but not disk.trg. Still trying to fing out the difference.
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 91 December 21, 2022 04:50
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 18:45
AMI interDyMFoam for mixer danny123 OpenFOAM Running, Solving & CFD 4 June 19, 2013 04:49
Parallel LES computation stops with reason vvqf OpenFOAM Running, Solving & CFD 4 March 6, 2006 07:55
Reading the old post massages subhash Siemens 1 June 25, 2002 14:04
