How to eradicate the warning turbulent viscosity ratio (of 1e5) in an array of two wi |
December 2, 2014, 23:29 |
ijaz fazil
Rep Power: 13 |
Hi I'm running FLUENT simulation of NREL Phase VI turbine, I'm doing CFD analysis of two turbines placed in an array. It is a 10 meter dia two bladed turbine, rotating at 72rpm. I have placed the second turbine at 100m and 150m behind the first to know effect of wake on the second turbine. Whenever I run the simulation, I get the warning turbulent viscosity ratio exceeds 1e5 in this much number of cells and it goes on increasing, also continuity value instead of decreasing it goes on increasing.
Can anyone suggest me how to eradicate this error? |
Turbulent viscosity ratio | Balaji | FLUENT | 5 | May 27, 2014 03:47 |
Ratio of eddy viscosity to molecular viscosity : Laminar or turbulent flow? | JuPa | CFX | 7 | September 9, 2013 07:45 |
[Gmsh] discretizer - gmshToFoam | Andyjoe | OpenFOAM Meshing & Mesh Conversion | 13 | March 14, 2012 04:35 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel | nuimlabib | Main CFD Forum | 0 | August 4, 2009 00:05 |
