May 13, 2014, 10:27 |
Gas Density Problem
Yasser
Rep Power: 12 |
Hi, All
I have a model consists of two concentric pipes and a gas in between. The ambient air surrounding the outer pipe. The inner and outer pipes made of aluminum and have heat sources (W/m3). The analysis will be 2D Planar, Steady state and check the gravity. Why when i changed the polynomial of gas Density, there is no changes in the temperature profile happens??? Thanks all |
May 13, 2014, 11:49 |
Flavio
Rep Power: 15 |
Hello Yasser,
can you post a picture of your system? Are you using a conformal or non-conformal mesh? Regards
Bionico |
Density boussinesq Problem | matrix-1.0 | FLUENT | 9 | January 17, 2014 21:17 |
Density problem in fluent | flow_CH | FLUENT | 33 | December 15, 2013 06:49 |
A problem about density in liquid air definition | alloveyou | CFX | 2 | June 14, 2012 14:20 |
Gas Dynamic Problem | afifi | Main CFD Forum | 0 | May 5, 2009 06:41 |
gas species density | faber | Main CFD Forum | 2 | February 24, 2005 15:29 |
