block the back flow from the outlets
Old   May 17, 2014, 17:19
Default block the back flow from the outlets
Astio Lamar
asal is on a distinguished road
Dear all
Hello!
I want to simulate a cube in transient with one inlet and two outlets which is over pressurized by about 10 Pa. first only one outlet was set to pressure outlet and the other to wall. After it is converged, I set the other outlet to pressure outlet with zero Gauge pressure to find out how much it takes to release this 10 pa of over pressure and get in to about 0 pa.
When I did this, I had a lot of back flow from the first outlet in to the domain, so pressure was never get back in to the 0 pa!
So, is there any way to block this back flow, to not maintain the pressure?
thanks.
asal is offline   Reply With Quote
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 13:00
Back flow problem in gas cyclone lakhi FLUENT 0 August 31, 2012 04:27
foamLog not solving for Ux, Uy, Uz aerospain OpenFOAM Post-Processing 5 April 18, 2012 10:01
Flow visualization vs. Calculated flow patterns Francisco Saldarriaga Main CFD Forum 1 August 2, 1999 23:18
computation about flow around a yawed cone Tylor Xie Main CFD Forum 0 June 9, 1999 07:33
