May 31, 2014, 02:11 |
time step size
Ra'na
Rep Power: 12 |
Hi
I would like to know the relationship between the courant number and time step size. I am modeling a micro combustor with inner diameter of 5 mm and 50 mm length.the grid size is about 25~50 micrometer and the flow velocity is about 2.2 meter per second. I want to capture moving flames.i try time step size of 0.01,0.001 and 0.0001 but the solution will diverge soon.Please give me a tip about it. thank you for your attention |
Transient simulation not converging | skabilan | OpenFOAM Running, Solving & CFD | 14 | December 16, 2019 23:12 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Sudden jump in Courant number | NJG | OpenFOAM Running, Solving & CFD | 7 | May 15, 2014 13:52 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
