Path status in DPM BC UDF
Like Tree1Likes
  • 1 Post By pakk
Old   February 20, 2006, 08:28
Default Path status in DPM BC UDF
HS
Hi again!
I am writing a DPM boundary condition as a UDF.
After executing some lines of code, I would like to use the standard "escape" boundary condition. Is all I have to do to return the correct path status then? And which one should it be? return PATH_STOP; ?
Thanks, Henrik
Old   February 20, 2006, 08:31
Default Re: Path status in DPM BC UDF
HS
Maybe I should mention, the ones available are:
PATH_END
PATH_ACTIVE
PATH_BREAK
PATH_ABORT
PATH_STOP
/Henrik
Old   June 12, 2014, 04:14
SJSW is on a distinguished road
Thank you, HS. It's helpful to know these functions.
The "escapse" condition seems to be attained at "wall" boundary condition when using "PATH_END," but I don't know if it works at the "pressure-outlet" boundary condition. Ther eare some explainations about the DPM boundary condition such as "reflect," "trap," ",escape" "wall-jet,""wall-film," and "user-defined," shown in the tag "DPM" of the boundary condition "Wall" (ANSYS14.0).
and could you tell me where and how to find look up functions like PATH_END or PATH_STOP, for I never see it in a manual and don't know its meaning.
SJSW is offline   Reply With Quote
Old   June 12, 2014, 04:41
pakk will become famous soon enough
Fluent UDF manual 2.5.1:
"For the return status PATH_ACTIVE, the particle continues to track. For the return status PATH_ABORT, the particle will be stopped and considered to be aborted. For the return status PATH_END, the particle will be stopped as well, but considered to have escaped from the domain."
If you want a particle to be "trapped", use PATH_ABORT; if you want a particle to be "escaped", use PATH_END.
Honestly, I don't know if there is any aspect in which Fluent treats "trapped" particles differently from "escaped" particles, but if I used this I try to choose the most logical condition in my situation.
As of Fluent 15.0, there are seven different statuses (see dpm_types.h, somewhere in your Fluent folder):
PATH_END
PATH_ACTIVE
PATH_BREAK
PATH_ABORT
PATH_STOP
PATH_NON_LOCAL_PERIODIC
PATH_NON_LOCAL
They are listed without explanation, and I don't know more. I would guess that PATH_BREAK indicated a break-up of a particle, and that PATH_NON_LOCAL_PERIODIC and PATH_NON_LOCAL might have to do with parallel issues. I don't know when PATH_STOP should be used, nor what it does.
wc34071209 likes this.
pakk is offline   Reply With Quote
Old   June 12, 2014, 07:12
Topic "Discrete Phase Boundary Condition Types" in ANSYS14.0 manual has some explanations about these boundary condition types: "reflect," "trap," ",escape" "wall-jet,""wall-film," and "user-defined."
When "Wall" boundary condition and UDF file with "PATH_XXXX" replacing "PATH_ABORT" the code described in 2.5.1. DEFINE_DPM_BC 2.5.1.3. Example 1, whch is an example of inert particle rebound at wall, some functions such as "ABORT," "BREAK" and "STOP" can't be distinguished.
Somehow, "ACTIVE" seems have some particle dispeared??
ABORT
ACTIVE
BREAK
END
STOP
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
DPM with UDF - Step-by-Step Procedure???? Prashanth FLUENT 3 April 3, 2009 17:45
DPM - UDF for fluctuating bubble size Jaroslav Kotara FLUENT 1 April 19, 2006 09:02
Boundary Condition UDF for DPM Nicholas Wood FLUENT 0 June 16, 2004 09:02
