June 11, 2014, 11:58 |
Boundary conditions not met
I am trying to run a simulation for a relatively simple geometry: The bottom surface is a spline surface, the rest are simple walls. The inlet, outlet and the inside fluid exist but aren't displayed in this picture. In the boundary conditions I have left the 'interior-xxx' as generated by Fluent, and set inlet, outlet and walls as I want. The coarse vector field is: The fluid is obviously slipping in the walls, which I don't want. The interesting thing was when I investigated the Boundary Conditions part - I couldn't change any the settings for most walls, but for the ones I could - some were hardly an edge or a very small surface, for example: Any help would be much appreciated. Thanks, Nitsan. |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
[Netgen] boundary conditions and mesh exporting | vaina74 | OpenFOAM Meshing & Mesh Conversion | 2 | May 27, 2010 09:38 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
