June 22, 2014, 21:28 |
Internal flow operating condition?
Guy
Rep Power: 12 |
I am trying to simulate an internal swirl flow (compressible) in a cylindrical duct. I know the inlet boundary condition (flow speed/ pressure/ rotation speed etc.) and I assume 1 atm pressure outlet. I also realize that my (default) operating condition is set to 1 atm. Once I changed the operating condition, the axial velocity (simulation result) of the flow changes according to the new operating pressure, as if the operating condition is the bulk static pressure for my entire fluid domain. Now my problem is that I don't know what I suppose to set the operating condition to because I actually don't know the static pressure of the flow inside of the duct. My understanding is that once I have the inlet and outlet conditions, what happens in the middle of the flow should adjust accordingly. Having to set the operating condition for internal flows confuses me. If you can help, could you suggest what I should do with the operating condition in this case? And if I change the operating condition, what does this physically represent /or how would it interact with the pressure I initially set at the inlet ? Thank you very much! |
June 24, 2014, 02:31 |
Saman
hello
as i know , you must define your boundary conditions with respect to your operating condition. so when you change your operating condition, you must do the same on boundary condition, because : absolute pressure ( what we have in real ) = operating pressure ( what we guess about flow ) + gauge pressure ( what you use in your boundary condition settings) |
June 26, 2014, 00:15 |
Guy
Rep Power: 12 |
Thank you so much. That explanation helps a lot.
Total pressure and mass flow boundary condition at inlet | bscphil | OpenFOAM Pre-Processing | 3 | July 9, 2017 14:39 |
Volume flow rate boundary condition in OpenFOAM | mayank.dce2k7 | OpenFOAM Running, Solving & CFD | 13 | August 11, 2014 20:16 |
Question Regarding Modelling Internal Flow | Alteran | CFX | 1 | September 4, 2013 12:07 |
Airfoil boundary condition | Frank | Main CFD Forum | 1 | April 21, 2008 18:36 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 05:44 |
