July 3, 2014, 09:07 |
Sinusoidal Pressure inlet
Rafau
Rep Power: 12 |
Hey,
I want to set boundary condition - sinusoidal pressure inlet at circle shape(2d). I think my UDF is not correct, can you take a look? #include "udf.h" DEFINE_PROFILE(unsteady_pressure, thread, position) { face_t f; real t = CURRENT_TIME; begin_f_loop(f, thread) { F_PROFILE(f, thread, position) = 100 + 200*sin(500.* t); } end_f_loop(f, thread) } |
July 3, 2014, 10:03 |
Rep Power: 26 |
I don't know if it is correct, because I don't know what you exactly want. "sinusoidal pressure inlet", what does that mean? Something has a sinus-shape, but what? The pressure as function of time? The pressure as function of position?
Your code looks like the pressure is a function of time. Is that what you want? And what makes you think that your UDF is not correct? Are the results not what you expect? |
July 3, 2014, 10:13 |
Rafau
Rep Power: 12 |
thank you for fast response ;-)
I want to model point (exactly it is the small circle in huge ambient) which is point-sound source. That's why I need to apply p(t) function. Sinusoidal would be the best. I've read some UDF tutorials, but most of them were focused on inlet at pipe like a straight line(2d). Some mistakes i have made were connected with timestep size. (but few question to left) 1. in eq. F_PROFILE(f, thread, position) = 500 + 300 * sin(500000.* t); 500 is some const 300 is an Amplitude 500000 would be "w" - omega (angular velo)? correct? |
July 3, 2014, 10:21 |
Rep Power: 26 |
If you use F_PROFILE(f, thread, position) = 500 + 300 * sin(500000.* t); the result is:
Average pressure is 500 Pa. (Gauge pressure, the absolute pressure depends on what you set as operating pressure.) Minimum pressure is 500 Pa - 300 Pa = 200 Pa. Maximum pressure is 500 Pa + 300 Pa = 800 Pa. Every 2*pi seconds (6.28... s), there are 500000 "sine shapes". In other words: your point has a frequency of 500000/2pi = 79.6 kHz. To resolve this, your time step needs to be in the order of microseconds. |
July 3, 2014, 10:27 |
Rafau
Rep Power: 12 |
I have realized that few minutes ago. Anyhow i really appreciate your response. That makes me sure of myself.
thank you Pakk |
sinusoidal udf |
2D Hypersonic Inlet in FLUENT - Convergence Issues | Fraisdegout | FLUENT | 6 | December 15, 2016 02:07 |
"Pressure Inlet" Boundary Setup | Wijaya | FLUENT | 15 | May 18, 2016 10:08 |
Pressure Outlet Guage pressure | Mohsin | FLUENT | 36 | April 29, 2016 17:16 |
Assign static pressure at inlet | Tanjina | FLUENT | 0 | November 3, 2013 11:34 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
