UDF about boiling phenomenon
Old   July 4, 2014, 03:19
Default UDF about boiling phenomenon
JeongGyun Ham
orchiders is on a distinguished road
Hi. everyone.
I’m studying boiling phenomenon and carrying out the vof simulation on bubble growth when boiling.
A boundary between liquid and vapor is not clear.
So I assumed that
0< volume fraction <0.5 : water
0.5< volume fraction <1 : vapor
DEFINE_INIT(my_init_function, domain)
Thread *t;
Thread **pt;
Thread **st;
cell_t c;
Domain *pDomain = DOMAIN_SUB_DOMAIN(domain,P_PHASE);
Domain *sDomain = DOMAIN_SUB_DOMAIN(domain,S_PHASE);
real xc[ND_ND], vof1, vof2;
mp_thread_loop_c (t,domain,pt)
if (FLUID_THREAD_P(t))
Thread *tp = pt[P_PHASE];
begin_c_loop (c,t)
C_CENTROID(xc,c,t);
vof1=C_VOF(c,tp);
if ( 0.5 < vof1 )
C_VOF(c,tp) = 1;
end_c_loop (c,t)
mp_thread_loop_c (t,domain,st)
Thread *sp = st[P_PHASE];
begin_c_loop (c,t)
C_CENTROID(xc,c,t);
vof2=C_VOF(c,sp);
if ( 0.5 < vof2 )
C_VOF(c,sp) = 0;
end_c_loop (c,t)
and I wrote UDF. but It didn’t operate.
Would you please do me a favor? Please give me reply anytime you feel free. Thank you!
orchiders is offline   Reply With Quote
Old   July 4, 2014, 03:38
pakk will become famous soon enough
Does it fail when you compile it? Or when you interpret it? Or when you load it? Or when you run it?
What are P_PHASE and S_PHASE? Does the program know what to do with it?
(You calculate xc, but never do anything with it. That will not cause any problem, but you could remove it, to make the code smaller.)
pakk is offline   Reply With Quote
Old   July 4, 2014, 03:56
JeongGyun Ham
I arppreciate reply to my question.
I succeed UDF compile. however when operating simulation, Error: Divergence detected in AMG solver: pressure correction.
P_PHASE and S_PHASE is first phase(vapor) and second phase(liquid).
To use C_CENTROID, I defined xc[ND_ND].
Old   July 4, 2014, 04:18
Yes, to me that is clear, but is it also clear to the program? Does the program know what P_PHASE is? Is it something defined by Fluent? (I never saw it before.) Or is is something you defined elsewhere?
The only use that C_CENTROID has, is to give a value to xc. You never use xc, so you can remove xc and C_CENTROID without consequence.
Ok, so at least Fluent can process your UDF. The problem occurs later in the calculation. But I think it might be caused by your UDF.
I can more or less see what your UDF does. But I don't know what you want it to do.
What do you want your UDF to do? (Be as exact as possible, for example "VOF calculations" or "separate water from vapor" is not detailed enough.)
Old   July 4, 2014, 05:10
JeongGyun Ham
I want to change VOF valvue to separate water from vapor.
0<VOF<0.5 : VOF=0
0.5<VOF<1 : VOF=1
Old   July 4, 2014, 05:23
And then? Continue the calculation? Make pictures? Calculate the volume occupied by water?
Old   July 4, 2014, 05:56
JeongGyun Ham
yes. I make picture of vapor bubble growth using calculated vapor volume fraction. and calcuate heat transfer rate and haet flux.
Old   July 4, 2014, 06:40
Two questions:
- Why do you need the VOF to be either 0 or 1? If the values in the simulation are in between, you can still make pictures, and do these calculations.
- Why do you continue the simulation after making these values 0 or 1? Fluent will get really confused by this, as you noticed.
Old   July 4, 2014, 06:56
JeongGyun Ham
As the boundary between water and vapor is not claer, I think a boundary using volume fraction value may be simplied. However, I agree your opinion 2. I think fluent is comfused, so errors happen. Do you have any ideas?
Old   July 4, 2014, 07:17
My opinion: don't change the VOF...
If you really want to have a strict distinction between vapor and liquid, add a user defined memory (UDM) and store the value there.
So instead of
C_VOF(c,tp) = 1;
write
C_UDMI(c,tp,0) = 1;
(and the same for 0)
In that way, you don't change the VOF, so Fluent will not get confused, and you can make the same plots by plotting UDM0.
UDF for Subcooled Nucleate Boiling Jake Fluent UDF and Scheme Programming 3 December 30, 2019 05:10
boiling in pipe (UDF) malay Fluent UDF and Scheme Programming 2 November 13, 2016 06:54
udf for boiling and condensation brusly FLUENT 0 November 22, 2006 22:17
udf for boiling and condensation brusly FLUENT 0 November 20, 2006 01:10
-What udf macro for boiling - thomas FLUENT 6 January 19, 2004 07:31
