Temperature limited to.. divergence after 30000 iterations |
July 8, 2014, 02:21 |
Sean
Rep Power: 17 |
I have convergence problems (temperature limited to...) using PISO and VOF scheme. The simulation convergens really well at the beginning. However, after 30000 iterations, it diverges and it shows that temperature is limited ....
If this happens at the beginning then I know how to adjust it. I know it is the energy equation that causes the divergence. (If I use a room temperature in the domain then no problems!) Why the divergence comes so late? then )The mesh and the domain are quite good. What are the problems? Thank you! |
Maximum number of iterations exceeded chtmultiregionsimpleFoam | Moncef | OpenFOAM Running, Solving & CFD | 28 | July 13, 2020 14:26 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Courant-number explodes after a lon while (icoFoam) | Rody- | OpenFOAM Running, Solving & CFD | 6 | January 29, 2014 04:27 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 12:50 |
