getting negative static pressure on airfoil surface
Old   July 15, 2014, 12:57
Default getting negative static pressure on airfoil surface
rishad rizwan
rishad is on a distinguished road
hello all!
i am doing a simulation in ansys fluent on flow over an airfoil at transonic speed. i got very good Cl , Cd and Cp distribution. but i'm getting negative static pressure when i'm monitoring surface points on the foil. also my static pressure contour shows negative area...
i've set the operating pressure = 101325 Pa
in B.C, gauge pressure = 0 Pa
i cannot detect the fault....as i went through some tutorials and followed them..... would you please say me how to encounter this problem of negative static pressure ?
thanks and regards.
rishad is offline   Reply With Quote
Old   July 15, 2014, 13:37
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
it simply shows that velocity is increasing
Far is offline   Reply With Quote
Old   July 15, 2014, 13:45
rishad rizwan
hello far
how can pressure be negative on airfoil surface ? shouldn't it be of some positive value ?
Old   July 15, 2014, 14:16
Far
Sijal
Originally Posted by rishad View Post
hello far
You are correct.
Absolute pressure = atmospheric pressure + gauge pressure
Results you are getting are in terms of gauge pressure, just add atmospheric pressure to get some positive value
Old   July 15, 2014, 14:27
rishad rizwan
thank you sir... but can you clarify me one more thing please ? in ansys tutorial : fluent_13.0_workshop02-airfoil.pdf , they set
# the operating pressure = 0 Pa
# Pressure (gauge) at Boundary condition, P = 71150.4 which they obtained from Po/P relation.
and in my simulation i set # operating pressure = 101325 Pa
and boundary condition # gauge P = 0 Pa
when i tried that of ansys tutorial i got positive pressure but my set up produces negative one... would u explain this please ? i need to know which one is correct ?
thank you for your time.
regards
airfoil analysis, flow over airfoil, negative static pressure, pressure contour
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
Negative static pressure Ariel CFX 1 June 25, 2007 17:54
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
